The Seafire
The Supermarine Seafire, or Sea Spitfire (the official name), was a naval development of the Spitfire, and was the first modern carrier based fighter fielded by the Royal Navy. Primarily developed for carrier use, the Seafire incorporated changes such as a tail hook, attachments for catapult use, and on later variants, folding wings. The Seafire was not the ideal carrier fighter and especially landings were difficult; but its performance outweighed the disadvantages. The Seafire had a short range, but its fast climb and agility made it a very good Fleet defence fighter. The last Seafire version Mk 47 was used in the Korean war, and retired in 1952.
Seafire III making a carrier landing - arrester hook can be clearly seen
As early as 1938, Supermarine had approached the Admiralty with a specifically designed Naval version of the Spitfire. However, due to circumstances beyond their control, the Admiralty ordered the Fairey Fulmar as the new aircraft of the Fleet Air Arm. In February and May 1940 the Admiralty asked the Air Ministry for Spitfires but on both occasions they were turned down. However, with the Admiralty's need for a capable carrier-based fighter to take up the task of combating Japanese Zero's or Messerschmitts which the Seafire II could perform that task, this need eventually led to the Fleet Air Arm being provided with the modified Spitfire land-based fighter to take up the combat roll. In 1941 the Air Ministry offered some Mk I Spitfires to the Navy but the Admiralty demanded the latest version in production, the Mk V.
Seafire III - first variant with folding wings
Finally, in September 1941 the Admiralty placed an order for 250 Spitfire Mk Va and Vb aircraft. They had, however, yet to decide on what modifications had to take place in order to make the aircraft suited to carrier operations. The land-based Spitfire V were then modified and renamed the Seafire II. The first Seafires were actually hooked Spitfires. The RAF loaned 110 Mk Va and Vb and three Mk II b's to the FAA for training purposes of which 59, including the II b's, had been fitted with arrester hooks. The modifications of the Spitfire did change the Seafire's characteristics somewhat. Approaches were difficult, visibility was limited at best, landing gear collapses were commonplace, and, the arrester hooks had a tendency to miss and bounce back into the fuselage frames which buckled the airframe. More were lost to breaking their landing gear in hard landings than to all enemy causes. As a low-level fleet defence interceptor, the Seafire was supreme, but it paid a price with its fragility.
Two of the ex-RAF Spitfire V aircraft were sent to the factory for full naval conversion. HMS Illustrious saw the first landing of Seafire on 10 February 1942. Eventually 163 ex-RAF aircraft were converted to the Seafire Mk Ib standard by the addition of arrester hooks, strengthened rear fuselages, slinging points, and Naval radios.
The next major version of the Seafire to enter service was the Mk F III in November 1943. This was the first version to be fitted with a folding wing which allowed below deck stowage for the first time. The initial batch of the Mk F III were quickly replaced by the Mk L III with the low rated Merlin 55 M engine. Over 1000 of these aircraft were produced. The FAA also had a requirement for recce and converted a number of Mk II and Mk III aircraft for this role by adding a pair of f.24 cameras. It was in this role that the Seafire was most successful.
The first Griffon powered Seafire, the XV, was introduced into service in May 1945. This was the first Seafire designed from the start with folding wings with production starting in Nov 1944. When the war ended eight FAA Squadrons were equipped with the Mk III and the other four were converting to the XV. Eventually the Fleet Air Arm used the F4U and F6F to fill the Fleet defender roll.
The Seafire XV was the first Griffon-powered Seafire. It combined the wing of the Seafire
III with the fuselage of the Spitfire V and the engine, cowling and prop of the Spitfire XII. The Griffon turned opposite the Merlin, but the "bend" of the airframe was not changed, which led  Griffon Spitfires to swing on takeoff. The Seafire XV arrived just too late for operational service in World War II. Despite all its problems, its low-level performance would have been good against the Kamikazes had an invasion of Japan been required.
Seafire Mark XVII
The Seafire also served with other Commonwealth and overseas Fleet Air Arms. The Seafire IIc MB190 was tested in the USA for possible use in 1944 with Seafire IIc MB190 being sent to Naval Air Test Centre, USNAS Patuxent River in May 1944 where it remained until VE-Day 1945. The Seafire was also tested by the SAAF,  Seafire F.III  LR783 went on trials with 7 SAAF squadron from June till July 1944. The French Fleet Air Arm (Aeronavale) received Seafire IIc in April 1948 (eg NN136), Seafire LIII after 1947 (eg NN312, NN303) and Seafire III as 54S.24 (Arromanches).
A total of 35 Seafires served with the Royal Canadian Navy (RCN) from 14 March 1946 to 29 April 1954. During this period the Seafire was flown operationally by 803 Squadron (June 1945 - August 1947) and 883 Squadron (September 1945 - November 1947) from the aircraft carrier HMCS Warrior and the Royal Canadian Naval Air Section which was a lodger unit at Royal Canadian Air Force (RCAF) Station Dartmouth (RCNAS Shearwater). The last Seafire was struck off strength from the RCN in April 1954.
The Seafire was withdrawn from Fleet Air Arm front-line service in 1951 and continued to serve with the RNVR until late 1954.
The final variant - Seafire 47 with contra-rotating propeller
The Designer ] Schneider Trophy ] The Prototype ] K5054 Facsimile ] Spitfire Profile ] Spitfire Marks ] Spitfire Variants ] Performance Data ] Technical Data ] Test Pilots ] The Factory ] Numbers & Arms ] Survivors List ] Memories ] Flying a Spitfire ] Technical Plans ] [ The Seafire ] The Spiteful ] The Seafang ] Spitfire Floatplane ] Spitfire Exports ] Spitfire & Other Prints ] Your Host ] Spitfire Sites ] Site Sponsors ]
Questions and comments are welcome although I have to admit that
I don't have the time to reply personally to all emails
Please make sure that you check the contents of the site first for the answer
to your question - if the answer is already on the site you will not receive
any response but if not, and I do have the time, I will attempt to find an answer...
If you are a modeller please also do not send me emails regarding colour schemes or plans.
The prototype, K5054 was officially "Duck Blue" and I have no details of paint codes.
You can also purchase plans from a number of sites on the internet -
this site offers free information and I do not promote or link to any commercial sites.
Please do not send an email if you are looking for information on flying a Spitfire.....
under UK CAA restrictions we are advised that such flights are not possible.
If you would like to find out what it is like to learn to fly then you can purchase my unique book,
"Learning to Fly in 21 Days" which is my account of gaining a Private Pilot Licence in 1997.
I have also written a number of other business management books,
some of which have been recommended by The Sunday Times,
and all of these can be purchased through Amazon -
search for Phil Stone using the box below.
Search:
Keywords:
Amazon Logo
To send an email click on the spitfire
This site is designed & maintained by PK Stone Consulting,
Specialists in Corporate Strategy, Business Planning,
Marketing Analysis & Strategy together with Fraud Prevention and Detection
Please visit our website - if you run a business of any description,
and have any problems, we are sure that we can help......
12 August 2008
